Author Topic: my 3XV...  (Read 32101 times)
Re: my 3XV...
« Reply #165 on: December 14, 2016, 02:59:50 PM »
Nice progress 8) Can you show us the porting tools you'll be using? I often though about porting my own barrels but not quite sure where to start..
Re: my 3XV...
« Reply #166 on: December 18, 2016, 12:56:34 PM »
This is what I use: I started with the Proxon equipment incl. a flex. shaft. Than I got a compressor with a air pressure hand piece. The last invest was the 90° hand piece from company Joke for better access into the transfers....
Re: my 3XV...
« Reply #167 on: December 05, 2017, 11:43:04 AM »
So here is another question for the ones who know a bit more about the SUGO stuff   :D
Can somebody enlighten me what's about the so called "SUGO frame modification"? Was that something to reinforce the frame for the higher requirements when doing serious racing with the 3XV?
cheers
Juergen
Yuri
Re: my 3XV...
« Reply #168 on: December 05, 2017, 07:48:05 PM »
I have never seen that ?
Re: my 3XV...
« Reply #169 on: December 05, 2017, 09:35:32 PM »
Nice work
Is it not the brackets for the seat? Only mod I know of.
Re: my 3XV...
« Reply #170 on: January 04, 2019, 09:03:40 AM »
So while still working on the cylinders I also upgraded the front brakes. I got legs from a R6 (RJ095) and Brembo calipers from a Suzuki with 300mm discs from a FZR600...
  • Kildare, Ireland
Re: my 3XV...
« Reply #171 on: January 04, 2019, 09:22:59 AM »
Nice front end  (-P)
I'm thinking something similar for my road bike.
How does it compare  in length,stroke etc to originals?
Much work involved in fitting .?
Yuri
Re: my 3XV...
« Reply #172 on: January 04, 2019, 12:11:59 PM »
Nice what wheels is it ?
And what year R6 ?
Re: my 3XV...
« Reply #173 on: January 04, 2019, 01:53:46 PM »
The legs fit directly onto the SP tubes, same diameter, thread and final lenght, they are from the RJ095 which was the 2005 MY bike. The wheel is a 3,5" rim from a FZR400SP (as was before with the stock 3XV fork setup). The main issue was fitting the drive for the speedo, rest was only a bit adaption for the spacer and cutting 5mm of from the caliper mounting point to adapt to the 300mm discs (instead of the 310mm discs from the R6).
