Author Topic: Yuri's 3xv7 ( 93 3xv sp )  (Read 26013 times)
Yuri
Re: Yuri's 3xv7 ( 93 3xv sp )
« Reply #30 on: November 19, 2014, 06:27:41 PM »
I understand it is 6FI80-61 part number 239-14116-80
« Reply #31 on: November 19, 2014, 06:37:36 PM »
Are you running avgas?
It'll be leaner.
Yuri
« Reply #32 on: November 19, 2014, 09:38:43 PM »
I will run 95
that is the reason the sugo kit use R2/R4 neele jets
« Reply #33 on: November 19, 2014, 09:54:11 PM »
hi yuri
R4 are the leanest i run at altitude and that needle you're after runs in 38mm carbs
avgas uses a lot less fuel, like 450 mains leaded to 330 on avgas for example
im just hoping to help, looks like you're going lean
someone tell me im right or to shut up
Yuri
« Reply #34 on: November 19, 2014, 10:08:24 PM »
This is what I wast to follow
« Reply #35 on: November 19, 2014, 10:17:02 PM »
okay, what i mean is the TZ 93 needle with a R2 is lean for 95
but those are massive pilots
Yuri
« Reply #36 on: November 20, 2014, 05:41:40 AM »
I am terrible with jetting so that is good to know
  • Perth Australia
« Reply #37 on: November 20, 2014, 06:29:15 AM »
Then just remember that pump fuel ie unleaded you tune it to black , opposite to avgas tan colour .
Yuri
« Reply #38 on: November 20, 2014, 06:45:25 AM »
I will just put big jets in and drive the motor in
Then gife it to sum one to dyno end set it up properly
On my vj23 I was never able to feel even 3 jets up and 3 jets down  :-[
  • Perth Australia
« Reply #39 on: November 20, 2014, 09:43:31 AM »
Put an EGT sensor and do it yourself , then you are in control of your jetting , these days there are very few bike mechanics that can jet a 2 stroke .
Yuri
« Reply #40 on: November 20, 2014, 10:03:03 AM »
You are correct that will be a good infest meant
  • Perth Australia
« Reply #41 on: November 20, 2014, 10:58:48 AM »
 ;) just think of it as a tuning tool and be happy when you save money on not seizing .
« Reply #42 on: November 20, 2014, 10:59:46 AM »
Yip
Yuri
« Reply #43 on: November 20, 2014, 04:38:05 PM »
Do you have any links to nice EGT systems ?
« Reply #44 on: November 20, 2014, 05:25:11 PM »
