Author Topic: Yuri's 3xv7 ( 93 3xv sp )  (Read 22046 times)
Re: Yuri's 3xv7 ( 93 3xv sp )
« Reply #60 on: November 27, 2014, 10:17:44 PM »
I use the 6EN11- range in my 36mm SP carbs with corresponding nozzles
« Reply #61 on: November 27, 2014, 10:27:51 PM »
There you go yuri. Jools can help
Yuri
« Reply #62 on: November 28, 2014, 12:06:29 PM »
I was to laze to go get my money back from centurion yamaha so i just ordered the next needles
239-14116-A0 (4dp4 needles )
Then looking at the part numbers the needle jet must just be 1 size smaller
What do you think of this craze idea ?
« Reply #63 on: November 28, 2014, 12:14:31 PM »
Here is a link to the needle chart
 http://www.jetsrus.com/a_jets_by_carburetor_type/needle_mikuni.html
this doesnt help
the TZ needle i have is a 6F13-62
the 6F13 is represented on the list (sadly the 6N11 range isn't to find a match, can someone post that?) with dimensions that are nothing like my needle which measures as follows:
A-68
B-30
D1-3.10
D2-2.65
D3-2.65
D4-2.40
D5-2.05
D6-1.75
if you want to run unleaded and use a TZ needle i would match that up, remember by altering what you choose off the chart as you clip position you can get closer, your choice of mains can also take up any slack at the last 10-15mm of the needle. if you match this up you will need R6 needle jets
regards your last post, they are also not available, sadly.
Yuri
« Reply #64 on: November 28, 2014, 02:58:14 PM »
I will look on the second hand side then ...
« Reply #65 on: November 28, 2014, 03:00:00 PM »
it's a pleasure
Yuri
« Reply #66 on: December 01, 2014, 02:04:48 PM »
I found a set of used once !!!! ;D
Yuri
« Reply #67 on: December 06, 2014, 07:01:53 PM »
So after the needles was discontinued i got sum bottels for the sugo air pods
Yuri
« Reply #68 on: March 18, 2015, 06:46:01 PM »
So finaly my 36mm sugo needles have arrived !
« Reply #69 on: March 19, 2015, 08:29:43 AM »
Nice!
Now......do you think we may see you at a track sometime this year?  :)
Yuri
« Reply #70 on: March 19, 2015, 09:28:19 AM »
Lol
Honestly I do not think so but the motor will be dun soon  ::)
Edd
  • You are the creator of your own missery
« Reply #71 on: March 20, 2015, 11:49:09 AM »
Hi Scott
I honestly dont think Yuri knows how to ride ;D Been on his case ever since Noah boarded the Ark. He can bring the VJ 23 we dont discriminate against machinery used ;).
Edd
TZR 250 3MA1
TZR 250 3XV RS(Track)
TZ 250 3YL
RZ 350 Hybrid
YZ 250
RD 350 Hybrid
Yuri
« Reply #72 on: March 20, 2015, 03:52:55 PM »
Then I will do the TZR motor first when that is dun I will get the vi23 to run ....
The TZR must get a fram spry ...... So still lots to do
« Reply #73 on: March 20, 2015, 04:14:53 PM »
Come yuri. Go watch Scott crash! It's great fun. Lol
« Reply #74 on: March 20, 2015, 04:39:11 PM »
lol. How is your shoulder Paul?
