Author Topic: Yuri's 3xv7 ( 93 3xv sp )  (Read 18163 times)
Yuri
Re: Yuri's 3xv7 ( 93 3xv sp )
« Reply #180 on: September 16, 2018, 06:58:34 AM »
No hanging around on this You are a man of action  (-P)
I would be interested in a primary gear as Well if you were getting one made up .
I will look up that balancer shaft thanks . (-P)
I will let you know when i am going to get the gear cut
« Reply #181 on: September 17, 2018, 07:22:28 AM »
Why are you looking for a TZ balancer shaft? If I remember correct the only difference is that the TZ shaft is a bit lighter because the middle part of the shaft was cutted on a lathe.... That can be done easy at a machine shop.
« Last Edit: September 18, 2018, 06:58:36 AM by 41juergen »
Yuri
« Reply #182 on: September 17, 2018, 09:52:03 AM »
The reason is that the TZ crank has spline gears and normal tzr gears will not fit
So i change the shaft and get everything straight cut gears ...
vinny
  • Kildare, Ireland
« Reply #183 on: September 17, 2018, 10:02:18 PM »
Yes that would be great if you could   (-P)
I have a balancer shaft on the way . ;)
« Reply #184 on: September 18, 2018, 07:00:24 AM »
But the balancer shaft has the same connection setup for the TZR as well for the TZ gear. So you can mount the TZ gear on a TZR balancer shaft...
Yuri
« Reply #185 on: September 18, 2018, 11:30:08 PM »
Here you can see the spline on the tz balance shaft
When i ma back from Mexico i will take better photos
Yuri
« Reply #186 on: December 02, 2018, 09:26:56 AM »
I got this the other day
Now i only need pistons and custom gear for basket and crank
« Last Edit: December 02, 2018, 09:29:10 AM by Yuri »
Yuri
« Reply #187 on: January 06, 2019, 03:14:27 PM »
My new forks arrived todat
For the TZR
« Reply #188 on: January 14, 2019, 04:30:03 PM »
Oh good lord Yuri...those look amazing!  :o   What brakes will you use?
Yuri
« Reply #189 on: January 14, 2019, 05:20:13 PM »
Thanks
I am saving for a set of brembo GP4-RR
rvt2002
« Reply #190 on: February 13, 2019, 11:33:08 AM »
Ooooooooooooooohlinnsssssss. Bling bling  8) 8) 8) 8)
TZRtim
  • One day ill own a 3xv ...3ma...
« Reply #191 on: February 13, 2019, 09:08:02 PM »
That's one serious upgrade , very nice indeed  .  iv pondered getting light weight wheels but for 125r - think id struggle to find a manufacturer that would fit . Also if JMC were still in buisness id love to have the std steel braced swingin arm made in ally . Then the steel rear subframe ? Where does one stop ? One day when i have my own proper workshop id try making some of it myself  (-P)
May the wind blow light and your groups shoot tight - UKV...  Biker and shooter for life ...
  • NW London, UK
« Reply #192 on: February 13, 2019, 09:38:41 PM »
Tried Gia in Nottingham? Recall some of the guys moved there when Spondon Engineering closed down (I believe)  :-\
Firing on two....almost.
  • Yes, we have no Bananas
« Reply #193 on: February 25, 2019, 03:37:58 AM »
Thanks
Are you planning on doing a face plant or something ?? :))
Yuri
« Reply #194 on: February 25, 2019, 08:44:06 PM »
Lol that is a good question
