Author Topic: Refurbished TSA Exhausts  (Read 990 times)
4l04ever
« on: June 13, 2017, 10:37:55 PM »
Look a lot better now :-)
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
Zeeltronic Ignition System
Re: Refurbished TSA Exhausts
« Reply #1 on: June 14, 2017, 12:23:10 AM »
look very tidy mate, How did you clean them up ?
4l04ever
« Reply #2 on: June 14, 2017, 10:33:38 PM »
I used a short bristled brass brush to get most the crap off, then used 400 grit wet and dry to shine up a bit.  Finally cleaned with degreaser and sprayed with VHT clear lacquer which says it is good for 800 degrees....
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
  • Perth Australia
« Reply #3 on: June 15, 2017, 04:13:07 AM »
Do you have to bake the Vht paint ?
4l04ever
« Reply #4 on: June 15, 2017, 06:40:23 PM »
Yes, but I used a heat gun up the exhaust for about 10 mins on each one, then will do a few heat cycles on the bike.
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
« Reply #5 on: June 15, 2017, 11:01:48 PM »
Good result.
you at Cadwell pk next weekend ?
4l04ever
« Reply #6 on: June 15, 2017, 11:30:26 PM »
Yes, will be there.  Will see how the lacquer holds up to a good thrashing. :-)
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
TZ750E
  • Old TZ750 rider
« Reply #7 on: August 26, 2017, 11:05:22 AM »
VHT is the best stuff I have found for pipes and engines. I use the satin black then build up the clear depending on what finish you want
Cheers,
Don
