Should have looked at the big picture. I realise the thrust rod end goes into the outer cover to hold it in position. The hole in the pressure plate is just a clearance hole. All this stuff looks good, bearing, washer, outer cover etc. so the noise must be coming from behind the clutch stack, I will carry on investigating.
