Author Topic: CMR TZ750 Build  (Read 4862 times)
Re: CMR TZ750 Build
« Reply #15 on: July 31, 2017, 11:49:29 PM »
You'll have to post up a photo of the size of your gonads to be even considered  ;D
Re: CMR TZ750 Build
« Reply #16 on: August 01, 2017, 07:07:06 AM »
Hi Jools,
I think you know this site, right? There are a lot other out there having the thickness as we have....  :))
http://natsforum.net/viewtopic.php?f=9&t=632
Re: CMR TZ750 Build
« Reply #17 on: August 01, 2017, 08:25:12 AM »
Hi Juergen
yes I used to post on this Forum, but I haven't for a while.
Re: CMR TZ750 Build
« Reply #18 on: August 01, 2017, 08:28:24 AM »
Hi Jools,
What are the pipes that you have fitted ?
Re: CMR TZ750 Build
« Reply #19 on: August 01, 2017, 08:31:50 AM »
Hi Jools,
I also note you changed from Brembo F08, to AP Lockheed to Brembo Gold line front callipers......
Are you wanting to sell the Lockheeds ?? ???
Re: CMR TZ750 Build
« Reply #20 on: August 02, 2017, 04:27:05 AM »
Gonad pics as requested http://s1366.photobucket.com/user/Mellorp/slideshow/Old%20Race%20Pics?sort=3
Re: CMR TZ750 Build
« Reply #21 on: August 02, 2017, 09:54:21 AM »
Sorry Jools, only to make sure, unfortunately it's not my thread... :))
Re: CMR TZ750 Build
« Reply #22 on: August 02, 2017, 10:04:05 AM »
I never doubted it for one minute mate  ;)
That Manx trophy is impressive in itself  (-P)
  • Perth Australia
Re: CMR TZ750 Build
« Reply #23 on: August 03, 2017, 01:03:49 PM »
Jools what do you mean my other one  :o
Re: CMR TZ750 Build
« Reply #24 on: August 03, 2017, 11:31:45 PM »
We all know that one is never enough............
The engine I'm building here is for my CMR Framed TZ750. I'm keeping the original matching numbers bike in the photo above as it is. Its still raceable but the cases have a limited life.
This is the rolling chassis as I last worked on it:
P9150087_zpsee3ga9qf by Julian Hardy, on Flickr
P9130085_zpsvn1kplsa by Julian Hardy, on Flickr
I may not use that fairing though
Re: CMR TZ750 Build
« Reply #25 on: August 10, 2017, 07:03:39 AM »
Bit of an update on this project.
The last few weeks have been spent scouring t'internet looking for the "small" bits and pieces required to assemble the bottom end, gearbox, selector mechanism, countershaft and ignition shafts ready to install.
Its been a long drawn out process but I have been pleasantly surprised I've been able to amass 95% of the missing parts from all 4 corners of the globe as well as pulling in some favours.
Now its sit back and wait for the packages to arrive.  ;)
Re: CMR TZ750 Build
« Reply #26 on: August 10, 2017, 12:36:50 PM »
Once engine is together what are the next steps? Have you got carbs and pipes?
Re: CMR TZ750 Build
« Reply #27 on: August 11, 2017, 02:08:14 PM »
I've got several Lectron Carb options between 34 and 38mm, but will probably go with 36mm powerjet type Paul.
As for pipe Swarbricks have been a favourite of mine, and he is now listing an improved power set in kit form which is ideal as I can tack them in place then TIG them off the bike.
Dennis Trollope has supplied a set of NOS reedvalves (kerching!) and TZMike produces inlet rubbers which are winging their way over as I type.
There are still lots of niggling little issues to decide and sort out one of them being the ignition. I have sort of convinced myself to get a Zeel and go total loss with a lithium battery, as they are a reasonable price.
The annoying part is waiting for all of the small parts coming in from various suppliers as each part is holding up a stage of the gearbox assembly.
One other part giving me grief is the throttle. Standard TZ750 twist grip has four cables and you need a second mortgage if you can find one, being magnesium. So I'm looking at using a V Twin TZ twin cable twist grip with two splitters in each cable. I've tried buying various cheap twin pull cables off ebay to look at but they mostly don't have enough pull range for the larger carbs.
So the next thing is to contact Venhill to see if they can offer any suggestions.
  • Perth Australia
Re: CMR TZ750 Build
« Reply #28 on: August 21, 2017, 01:59:24 AM »
What did the big kawasakis and suzukis use those water bottle bikes or kettle bikes use ?
  • Perth Australia
Re: CMR TZ750 Build
« Reply #29 on: August 21, 2017, 02:28:09 AM »
Some motivation Jools
