Author Topic: 3XV R/RS main centre crank seal - possible order/buy in  (Read 6742 times)
« on: October 25, 2017, 09:06:59 PM »
So I'm starting an official post I contacted the seal company about. Getting the seals reproduced they all ready did for another company. The other company will not sale them separate from a crank rebuild services within jspan.
So the problem is the seal company wants a minimum order quantity was 100 units at $5 per seal. That's  $500 for the order still haven't gotten an offical quote.
Thinking might have to do a 5 seal minimum depending on if there's even enough interested to make worth the effort.
Will see if possible to try and get the order limit lowered from the manufacturer.
Re: 3XV R/RS main centre crank seal - possible order/buy in
« Reply #1 on: October 25, 2017, 09:54:05 PM »
I'll support the cause up to $25.
SuperBee
« Reply #2 on: October 25, 2017, 10:17:30 PM »
I can manage $25 too
4l04ever
« Reply #3 on: October 25, 2017, 11:14:23 PM »
I would be in for $25 too :-)
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
Zeeltronic Ignition System
« Reply #4 on: October 26, 2017, 09:44:48 AM »
I'm in (-P)
turbo_d202
« Reply #5 on: October 26, 2017, 02:47:36 PM »
I'm in :)
« Reply #6 on: October 26, 2017, 06:47:02 PM »
So far not enough interest for a 100 seal order I asked if possible to only get 25 done. But the price could go up as a result don't wanna be stuck with a bunch of left over seals.
Edd
  • You are the creator of your own missery
« Reply #7 on: October 27, 2017, 10:20:25 AM »
I am in for a few seas 4 in total.
Edd
TZR 250 3MA1
TZR 250 3XV RS(Track)
TZ 250 3YL
RZ 350 Hybrid
YZ 250
RD 350 Hybrid
« Reply #8 on: October 27, 2017, 02:52:10 PM »
I got the manufacturer to agree to do 50 seals instead of 100 that's better they did not mention anything about price increase per seal either.
« Reply #9 on: October 27, 2017, 05:56:16 PM »
Nice! Thanks for your effort with this. We just need 4 more pledges :)
No.406
  • Lee
« Reply #10 on: October 28, 2017, 10:30:24 AM »
Put me down for five, although hoping I never need them (jinxing myself).  Yamaha stopped selling these recently, yes?
What company are you lining up to make them?  (wondering about quality)
SeaR1ck, where are you?  Geographically, that is - not seeing anything under your user name.
1991 TRZ250R | 3XV-047***
« Reply #11 on: October 28, 2017, 10:56:30 AM »
T2 racing in Japan is selling a crank overhaul service for R cranks now that the center seal has gone nla with yamaha. They posted pics of the replacement seal which had dimensions and manufacturer markings on it. They stated that they wont sell the seal seperately hence SeaR1ck just contacting the manufacturer directly.
Quality should be good as T2 does replacement seals for the nsr as well?
« Reply #12 on: October 28, 2017, 05:39:22 PM »
I'm in Seattle area (Renton) the seal manufacture also does stuff for car engines. So it should be good quality I have bought one of 2T reproduced water pump shafts with gears over the summer and it was good quality no reason why they would make a crap seal for a crank rebuild. The seal manufacture said it is made from vitron material.
No.406
  • Lee
« Reply #13 on: October 28, 2017, 08:38:41 PM »
Got it.  https://en.wikipedia.org/wiki/Viton
If the seal mfg is likewise Japanese, sounds like clear sailing.
I have an OEM seal for comparison if we need it (93101-40162).
4l04ever
« Reply #14 on: October 28, 2017, 09:40:56 PM »
May be worth asking Chris Applebee if he wants some, as he rebuilds a lot of v-twin cranks?
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
