Author Topic: 3MA Belly pan hinge wanted...  (Read 911 times)
morepower
« on: January 10, 2018, 10:33:37 PM »
So the 3ma has a small piece of the fairing lower which has broken and one half of the hinge is missing. I want to try and get at least the half with the pin or both sides if possible
Cheers guys....
Re: 3MA Belly pan hinge wanted...
« Reply #1 on: January 10, 2018, 11:12:23 PM »
I think I can help you. I'll PM you at the weekend.
chubba
« Reply #2 on: January 10, 2018, 11:12:42 PM »
I might have them I'll let you know tomorrow unless you get sorted before then
morepower
« Reply #3 on: January 11, 2018, 01:10:13 AM »
Cheers guys...... Thats ace......
chubba
« Reply #4 on: January 11, 2018, 07:03:26 PM »
I have 2 female ones and only 1 male which is a bit rough which side did you need
morepower
« Reply #5 on: January 11, 2018, 10:10:36 PM »
I think its the female side..
chubba
« Reply #6 on: January 11, 2018, 10:30:59 PM »
I'll clean them up and post a pick tomorrow aft let me know if you need em
morepower
« Reply #7 on: January 11, 2018, 10:46:41 PM »
I will go and check in the garage later and see which one it is.... It is the most rearward one as there is a bit of fairing missing so I need to sort out a bit of black plastic for them to weld into the broken bit.. I have some old panels from other bikes I can use for that... lol..
Thank you again....
chubba
« Reply #8 on: January 11, 2018, 11:44:23 PM »
These are old panels so I can chop around the bracket so you can plastic weld it in
« Reply #9 on: January 12, 2018, 08:09:09 AM »
Looks like you are sorted  O0
chubba
« Reply #10 on: January 12, 2018, 03:56:29 PM »
This is the rear female one,
Pm me if you need it I can cut as much of the panel as you want
chubba
« Reply #11 on: January 12, 2018, 03:57:50 PM »
Picture didn't attach sorry
morepower
« Reply #12 on: January 12, 2018, 07:58:29 PM »
Cheers... Its the male one which is the most rearward one on mine... Bit of a shame but at least I can now get it fixed and it will looks whole again....
chubba
« Reply #13 on: January 12, 2018, 08:02:57 PM »
The male one I have is salvageable not sure what Maccas ones are like
morepower
« Reply #14 on: January 15, 2018, 12:30:20 AM »
Ace... Anyone would do... I may be able to get a copy machined and do both male and female versions. I guess its just the same but has a drilled hole for the pin.
I would be happy with anything.... Message me if you have one and let me know what you want... Cheers guys...
