Author Topic: 3xv problems  (Read 501 times)
gubbyj
3xv problems
« on: January 19, 2018, 07:53:31 PM »
hi, everyone ive recently joined . brought a 3xv ive cleaned the carbs and got her running but seems to push the water out the radiator overflow once warm, ive noticed a small drip from bolt on bottom cylinder . also the revs seem to hold once over 6k until you blip the throttle again . any ideas /help would be great . (-P)
Re: 3xv problems
« Reply #1 on: January 19, 2018, 08:21:50 PM »
head gasket failed or heads/barrels not torqued down properly
gubbyj
Re: 3xv problems
« Reply #2 on: January 19, 2018, 08:25:36 PM »
cheers for reply. i will have the head off and check it out , any ideas on the correct torque  .would this also cause the sticking revs ?
Re: 3xv problems
« Reply #3 on: January 19, 2018, 08:47:04 PM »
Check that your radiator cap is still good.
The revving could be your carbs are out of sync after you took then off and cleaned them why the revs hang.
gubbyj
Re: 3xv problems
« Reply #4 on: January 19, 2018, 08:50:18 PM »
thanks , ill swap the radiator cap of my other bike give that a try and balance carbs . cheers for that
Re: 3xv problems
« Reply #5 on: January 19, 2018, 09:56:55 PM »
Fix one thing at a time. If it's ingesting water messing with the carbs will make no difference
gubbyj
Re: 3xv problems
« Reply #6 on: January 19, 2018, 10:14:32 PM »
 (-P) (-P) ill sort the coolant problem first
gubbyj
Re: 3xv problems
« Reply #7 on: January 24, 2018, 08:15:50 PM »
thanks everyone , managed to sort out the cooling problem and the revs sticking was down to the throttle cable routed wrong and the inlets have cracks on the carb rubbers.     thank you :)
