Author Topic: 3xv fuel tap  (Read 412 times)
Ivor2Stroke
  • Nottingham,England
3xv fuel tap
« on: March 09, 2018, 12:26:41 AM »
hi does anyone have a spare fuel tap kicking around mine leaks and was trying to keep the bike as original as possible,thanks
Re: 3xv fuel tap
« Reply #1 on: March 09, 2018, 01:46:47 AM »
Might be worth a simple strip, clean, lube and rebuild if you haven't tried that already? I've cured a few leaking taps that way myself  (-P).
morepower
Re: 3xv fuel tap
« Reply #2 on: March 20, 2018, 04:28:50 PM »
You can still buy seals brand new and they are really cheap.. Fowlers sorted out some for mine on the 3MA and for a few quid it was fixed.
Re: 3xv fuel tap
« Reply #3 on: March 21, 2018, 04:22:21 AM »
Failing that an RGV one is a common replacement and does away with the vacuum diaphragm system - the cause of most leaks.
