Author Topic: Clutch Assembly  (Read 407 times)
robel
  • Putting a stock TZR250 1KT back on the road.
Clutch Assembly
« on: March 29, 2018, 10:57:44 AM »
Done a total rebuild on my 1KT engine and gearbox. Engine runs smooth, gear selection smooth BUT when I pull back the clutch lever it feels as though the clutch springs are compressing but the clutch plates don't seperate so the engine stalls when I select gear.  I did not soak the clutch plates in oil before reassembly, could they be binding?  Or any other reason?  Thanks.
Tzr3ma
Re: Clutch Assembly
« Reply #1 on: March 29, 2018, 01:08:47 PM »
Have you lined up the 2 dots one on cover and one on basket
robel
Re: Clutch Assembly
« Reply #2 on: March 29, 2018, 01:31:04 PM »
Uuuhhh no!  I'll take a look.
robel
Re: Clutch Assembly
« Reply #3 on: March 29, 2018, 01:44:05 PM »
When you say ciover do you mean pressure plate?
Tzr3ma
Re: Clutch Assembly
« Reply #4 on: March 29, 2018, 04:41:15 PM »
Yes
Re: Clutch Assembly
« Reply #5 on: March 29, 2018, 04:58:06 PM »
I was not aware there was a dot on the basket and pressure plate on the 1kt/2ma.
No mention of lining up dots in the workshop manual,maybe applies to the 3ma.
The fibre plates only need soaking in oil before fitting IF they are NEW.
« Last Edit: March 29, 2018, 05:51:44 PM by teezer250 »
