Also on the sideline, getting a new frame guard made. From left, the design, original that disintegrated and the first 3D printed prototype. This sits on the frame by the countershaft sprocket. Yamaha made a dedicated 3XV part for the later 3XV's, the early ones use the 3MA part. I suck at 3D modelling so will probably have to print a thousand more before it fits correctly.
Also doing bits for a SPR leak down tester. This will plug the exhaust port. This is a little easier so far haha
, yeah that soda blasting brings parts up real good, looks like your making good progress with reference to your pitted swingarm in need of touchup, mines the same on one bike, are there paint codes for the frames and swingarms?
Paint codes are here:
http://pure2strokespirit.net/redandblueftp/color_charts/3XV%20Farbtabelle%20_%20color%20chart.html I have given these to a few paint shops and they always just go 'huh'. I had it matched in an aerosol can. 99% there I reckon. I'll take some pics once I have sprayed the swingarm:
I soda blasted the bad paint:
I suck at spray painting so it will most likely look like a baboon's bum when done in which case I'll probably get the whole thing sprayed.
Interested to know what they used for a seal head since I'm gonna be rebuilding my spr suspension soon.
He told me he had to custom make it but that could mean he just used another one that fits.. The dimensions he gave me were 12.5mm x 40mm which is the more commonly available size supposedly. Apparently the stock seal head is a 'Soqi' unit.
Your shop looks top notch.
Have you considered “CLR” for corrosion?
The shop is severely cramped and I miss my double garage
At least I dumped the crappy existing workbench and made my own from a thick kitchen counter. Much better.
The CLR stuff, is that for corrosion removal?
I could understand the legislation applying to new bikes from a certain date, but even 'old' ones too? Does this mean you will have to keep the SPR registered in perpetuity to retain exemption from the new requirements? I presume this is a 'New Zealand thing', but I'd be interested to know whatever you can tell me/us about it!
All new bikes entering the fleet for the first time this year has to have ABS. All secondhand bikes entering the fleet for the first has to have ABS by end of next year. I can understand the reasoning and all but it does mean no more imports of cool non-ABS bikes..
The SPR has only gone halfway into the system years and years ago. Never fully road registered before it was mothballed. So now I have to do it over and better on the safe side and get it done before the point of no return (even though it has once been complied, you never know what red tape may be hiding around the corner)
And yes, I'm wondering about the need to register until end of time for fear of losing the exemption. I'm hoping for sensibility to reign but yeah..
Relevant link:
https://www.transport.govt.nz/multi-modal/keystrategiesandplans/road-safety-strategy/abs-for-motorcycles/P.S. jealous of that mint looking spr/ sp/rs tank! How bad is the old one?
Tank on the SPR looks good from far but it's basically junk. Even when I got the bike back in the day it was full of pin holes. Back then I put some epoxy on it and called it a day, haha, have to shake my head at my early attempts at trying to fix stuff. Taking the bike apart now I still shake my head at the ham fisted repairs
The shame!
It got worse though, I thought "hey, let's leave the tank full of petrol for 4 years then it wont rust!". The ethanol in the petrol ended up having its way with the tank:
Rusted straight through. On both my bikes. So nowadays ethanol is not in my good books. (I picked up a spare SPR tank a few years ago, back then it was an arm and a leg but I just bit the bullet. Looking back it was actually fairly cheap compared to today's prices)
At least it's fairly easy to test if the petrol has ethanol in because you cant really trust what they say and all.
Add some food colouring to the petrol, give it a shake, if there is ethanol it will dissolve and colour the petrol:
If no ethanol it will just stay separated even after shaking:
You can get ethanol out by mixing the petrol with water, the ethanol will dissolve in the water then separate in two layers after which you can siphon off the petrol. Only problem is you lose some octane because the ethanol acts as an octane booster. Win some lose some etc..
So know your enemy! haha
