Author Topic: Replacement wheel bearings question  (Read 301 times)
  • NW London, UK
« on: April 14, 2018, 09:46:07 PM »
Can anyone recommend the better option for replacement wheel bearings for a 3XV1 please? Is it the preference to source genuine Yamaha bearings assuming they are still available or go for the equivalent SKF/Toyo bearing?
If the latter, can anyone recommend a source in the UK at all that they have used?
Many Thanks.
Still a student attempting to learn from the Mentors.
Re: Replacement wheel bearings question
« Reply #1 on: April 15, 2018, 03:01:31 AM »
Don't get genuine for wheel bearings. They are common off the shelf types. Yamaha uses NSK and Koyo so you should be able to source the exact same ones at a fraction of the cost. If you can't get those brands then any of the other reputable bearing brands will be more than fine.
  • NW London, UK
« Reply #2 on: April 15, 2018, 10:06:35 PM »
Much appreciated, will source some this week.  :) (-P)
