Author Topic: Indicator dash light not working  (Read 304 times)
Tzr3ma
« on: May 16, 2018, 06:22:52 PM »
Indicator dash light not working when indicators flashing on right side any ideas
Re: Indicator dash light not working
« Reply #1 on: May 16, 2018, 09:54:11 PM »
Bulb in the dash is burnt out?
Tzr3ma
« Reply #2 on: May 17, 2018, 08:31:13 AM »
Sorry should have put it works fine when left indicator on
« Reply #3 on: May 17, 2018, 04:06:02 PM »
Have you tried swapping the left/right indicators around to see if the problem moves?  A long shot, but at least you'd rule out the indicator.
ColinS5940
« Reply #4 on: May 17, 2018, 07:00:20 PM »
Have you got an led bulb in the dash? If so, it'll only work one way
Tzr3ma
« Reply #5 on: May 17, 2018, 09:16:45 PM »
Yes I have got a led bulb I will change it
ColinS5940
« Reply #6 on: May 17, 2018, 09:24:27 PM »
« Reply #7 on: May 18, 2018, 12:37:50 PM »
Typical Yahama turn signal wiring.
When flashing left hand, the current is passing in the indicator one way and when flashing right hand then the current goes the other way in the indicator.
If you want to use led bulb or standard led then you need a diode bridge like this
https://www.taydaelectronics.com/diodes/dbl104g-c1-single-phase-diode-bridge-rectifier-400v-1a-db.html
Tzr3ma
« Reply #8 on: May 21, 2018, 09:48:17 AM »
