Hi guys,
Trying to get some answers on a problem I have with the Zeel, Perhaps someone knows.
I connected the Zeel like it should, programmed a static angular of 80 degrees select tricker - and + on the pickup and programmed a flat 18 degrees line (till 10.000rpm)
She starts perfectly, and has a steady 18 degrees at idle (oem markings at idel are 18 degrees)
But ones you let the rpm rise and she is getting to its first set point (18 degrees from the set 18 degrees flat line)
She jumps somewhere on the flywheel, Witch is not right as it needs to be a steady 18 degrees
https://www.youtube.com/watch?v=e9i-VskzhfkHave tried different setups, switch wires on the pickup but can't let it work as it should
(however I can let it work correct, but not on the way it should)
The 80 degrees should be right as I have found 80,5 when reading out the Oem CDI.
Borut helps me with this but it seems to be a problem.
So my question is, does someone has had the same problem with his TZR125 or DT125R?
