Author Topic: new pipes + carbs  (Read 382 times)
17again
new pipes + carbs
« on: June 09, 2018, 10:08:32 AM »
so just added a set of pipes to my R1-Z unknown brand
next is the tzr 28mm carbs
would i need to change the settings of the carbs or leave them standard.
running standard air box
Re: new pipes + carbs
« Reply #1 on: June 10, 2018, 01:50:35 AM »
Generally bigger mains but its trial and error to figure it out.  You haven't provided any info on jetting specs so its a total guess for anyone trying to answer this question....
17again
« Reply #2 on: June 11, 2018, 08:25:20 PM »
standard tzr jets main is a 230 cant read pilots
« Reply #3 on: June 12, 2018, 08:38:48 AM »
What altitude are you at?  I am closer to 210 with stock setup and pipes but at 3500ft altitude.  If you are closer to sea level give it a shot with the stockers.  I didn't have to mess with pilots.   Running airbox less snorkle.
