Author Topic: Special 4DL engine  (Read 401 times)
  • Netherlands
    • TZR3MA
Special 4DL engine
« on: July 28, 2018, 03:54:42 PM »
This will not be a fast going project, as its between other projects ::)
But made a start with it so time to start a topic, for info and ideas.
Its about the same as Juergen with his 4FL vs 3XV I'm more into the 4DL vs 3MA
It needs less changing as bore/stroke are the same ;)
Have made a 3MA cylinder fit the 4DL crankcases, so the start is there.
More info: http://www.tzr3ma.com/3ma-cylinder-on-4dl-engine.html
The idea is as followed
1) 3MA cylinder
2) 3MA-SP head (thanks to Olivier's connections already present)
3) 3MA-32mm carb (wit TPS sensor)
4) Running on 3MA-00 CDI
5) Home made pipe
And hopefully a lot off fun to build it
« Last Edit: July 28, 2018, 04:01:15 PM by Louis »
  • Iwata sur Loire - France
Re: Special 4DL engine
« Reply #1 on: July 28, 2018, 07:08:52 PM »
Ha ha ha, the demon is in you  ;D
Cheers  ;)
« Reply #2 on: July 28, 2018, 11:07:24 PM »
Nice write up as always Louis...  :) I always enjoy your projects!
How well to the transfer ports line up with the case?
  • Netherlands
    • TZR3MA
« Reply #3 on: July 29, 2018, 12:00:07 PM »
That's guys for the commend :)
Martin,
Transfer ports needs work, have to widen them up a bid.
See here, but that is doable
A other change will be the reed block.
Want to use the Honda reedblock, as it is a bid shorter/widener
Need to open up the cases anyway
(Here with a oem reedblock)
