It seems like the part should be common for things like where the clutch cable connects to the lever, but I couldn’t find one. I didn’t look too hard, though.
I’ll post some pictures tomorrow. I found a copper cylinder at a boat store. I don’t know what it was supposed to be used for, but it was around 5mm diameter and the right length.
I drilled a hole through the side to clear the cable, about 0.050” I think. Then I drilled a larger hole (maybe 0.125”) about 3/4 of the way through for the soldered on cable end ferrule. Then, I used a Dremel cut off disk to cut a slot halfway through, aligned with the hole.
It’s hard to explain. But, once the cable is fed into the TPS housing, the new fitting is put on the end of the cable and is hooked to the TPS wheel.
It looks like these pictures:
