I'm collecting parts for my 3xv1 rebuild. I'd appreciate some help with a few questions before I start a "Project" thread.
1 - I have access to a "Pro-Shift" up and down semi-auto shifting device. I have never seen an auto-shift device mentioned here. Is this a good or bad idea on a 2T? Pro-Shift is made in UK and my partner had it installed on his ZX-6, but when his bike blew a head gasket, his builder convinced him to use a "Trans-Logic" auto-shift. Pro-Shift was a $5000 system when purchased. It will be mine to use, gratis.
2 - I'm ordering Wossner piston kits and have been made aware that re-plating tolerances need to be "looser" (0.06), as forged pistons expand more than cast versions when they are up to operating temps. Also, warm-up with forged pistons must be approached with more deliberation. Please educate me as to how/if this info applies to my 3xv1.2. (FYI - Martin 77 has ported my cylinders and skimmed the heads. I also, now have a Toomey Dual-Core, TZ Radiator).
3 - What is the advantage to higher output coils?
4 - Concerning my new radiator, the designer (Ed Toomey) says, "That for track work, I should dump the thermostat, keep an eye on my temp gauge and use a blocking system to control air flow to the Rad. What is the ideal temp for a 3xv under load on the track? It "seemed" to run best at 55C (before spitting its crank bearing). The rad has a pick-up for temp gauge built in. Thoughts on these cooling system suggestions will be appreciated. Toomey is an ex-racer, tuned TZ's for their entire model-life and produced an AMA national champ in 2001.
That's it for now. As always, thanks in advance for any knowledge/experience you can share.
