Author Topic: 1991 36mm SP needles ?  (Read 445 times)
Andy Bush
« on: March 16, 2019, 03:14:00 PM »
Afternoon everyone
My 91 SP is progressing nicely.
Had it on the dyno last weekend, and ran in to an issue
As it pulls through the midrange it encounters a rich patch between 8,500 - 10,000
It?s got the 36mm SP carbs on it, with the 633 nozzle. Currently has a 6FI3-62 needle.
Does anyone know what needle the rc-sugo kit included? Or maybe one they have found to work ok .
I do have an 6FI90-62 needles, which will be my next trial. Not sure how to read the code, as to what difference in shape / taper this will have over the other one.
Any help appreciated ????????????
Thanks
Andy
vinny
  • Kildare, Ireland
Re: 1991 36mm SP needles ?
« Reply #1 on: March 16, 2019, 03:37:56 PM »
Sorry for the stupid question but is it a 3xv or a 3ma you have  Andy ?
Andy Bush
« Reply #2 on: March 16, 2019, 06:21:54 PM »
It?s a 3xv mate
  • East Yorkshire and Bristol UK
    • GasketGuru
« Reply #3 on: March 16, 2019, 07:50:18 PM »
Sugo kit needle is the same as the 92 TZ 4DP so check the TZ manual for the number.
However, on the dyno  you'll already be full throttle there so i'm not sure changing the needle will change anything as you are already on the main jet.
What's going on with the air jets or power jets?
vinny
  • Kildare, Ireland
« Reply #4 on: March 16, 2019, 11:13:16 PM »
Ah ok it's a 3xv .
 you have the same carbs as me 36mm sp carbs.
Dan is on the money.
 I used  tz 4dp parts in mine they are pretty easy to find compared to sugo stuff .
I'm using race fuel so my jetting will probally be different .
What nozzles are you using .?
Andy Bush
« Reply #5 on: March 17, 2019, 12:29:49 AM »
Thanks guys
It had S0 nozzles in, with needle on the 4th clip from top. Was rich right up the 10k . Would just about pull through if you part throttled it.
Changed down to R5 nozzles which cleaned it up lots.
The tried the needle on 3rd from top . But this made it flat as a pancake off idle, to the point it wouldn?t pull away !
So back to 4th grove.
Down jetted the main, and lost power , and still had the flat spot.
So figured it might be the needle profile was all wrong.
I will try these other needles I have, and see if it helps.
Andy
  • Global Moderator
  • UK
« Reply #6 on: March 17, 2019, 01:12:46 AM »
I run 6FI80-61 needles in R3 633 needle jets, Andy. That's in 4DP TZ carbs, but it's in the ballpark for the 36s too I'd think as it's pretty much the recommended '91/92 Sugo base settings.
I think the 36s are a bit more of a challenge to set up if you block off the air jet completely as in the Sugo set-up. Doesn't the needle jet also sit at a slightly different height if using the 633s rather than the sugo type setters and the 610 type jet on top in the 36s? That might also be a factor if using the 633s? I remember with a mate's bike  some years ago that it was always a lot harder to get the jetting sweet with the oe 36s even using all the pukka Sugo jets and settings than the TZ carbs I was using. If you have access to a pair of 3YL or early 4DP 38s they might be worth trying as they seem a lot easier to set up in my experience.
« Last Edit: March 17, 2019, 02:00:05 AM by Warwick »
Andy Bush
« Reply #7 on: March 17, 2019, 12:14:59 PM »
Thanks Warwick
I was reading some of the old posts in the archive, and it seams this is a common issue with these 36?s !
The fact the 633 nozzle sits at a different height probably affects things.
I have these other needles...let?s hope they give some good results ????
Hoatso
« Reply #8 on: March 19, 2019, 06:10:27 PM »
It?s common to think the needle affects mid-rpm, but it actually affects mid-throttle. So, if there is a rich or lean spot, note the throttle opening.
If it is a problem with a certain rpm range during wide open throttle, this might be corrected by programming the vaj or power valve opening differently, as these change with rpm.
The emulsion tube in the carb also is rpm-dependent: as the rpm increases, the fuel level in the emulsion tube well lowers, exposing more air holes, and leaning the mixture. Folks don?t normally change this.
Scotty4321
« Reply #9 on: March 20, 2019, 08:29:36 PM »
Hi,
I managed to get reasonable results with a 91 SP on standard carbs and all std carb parts, bar the main jets.
I junked the VAJ blocks and the electronic power jets and simply tee'd together the pipes coming from the  carbs that went to the VAJ blocks. I bought a load of different sized air jets (the ones that fit the vaj blocks) and trialled them in the  end of the pipe.
Worked fine for me and I got the A/F ratio pretty good.
I did start playing with the duty cycle solenoids off an RGV. I'm convinced this offers the ultimate solution to mixture control across the rev range. Struggled with them though so didn't get them working You would need a zeel to try this though. Good luck Scotty
Andy Bush
« Reply #10 on: April 03, 2019, 11:48:42 PM »
Here?s the difference between the 3xv Sugo 610 needle jet and the tz 633 one.
Quite a difference in height.
Andy Bush
« Reply #11 on: April 03, 2019, 11:51:46 PM »
Have another dyno session booked for Saturday, and will be trying this full yec carb kit
Updates to follow
  • Global Moderator
  • UK
« Reply #12 on: April 04, 2019, 12:09:25 AM »
Cor, some YEC treasure there alright, Andy! The 7 was the round bore 32mm carbs though, wasn't it? I don't know off hand how different the kit carb internals were between the early 36s and the 32s though? I've seen little YEC inserts designed to sleeve the 36s down to 32. To allow running of the earlier bikes when they reduced the carb sizes in the proddie rules I imagine?
Going from my mate's bike some years ago, I always thought his poorer mid-range fuelling was linked to the primary type NJs with no air bleed at all to them. Don't think he ever quite got to the bottom of it - just lived with it.  Be interesting to see how you get on with all that posh brass though. Good luck!  O0 (-P)
« Last Edit: April 04, 2019, 12:35:08 AM by Warwick »
Andy Bush
« Reply #13 on: April 04, 2019, 12:23:45 AM »
Was just checking what model the 3xv7 was, and yes it?s the guilotine pvalve 3xv-20 cylinder one, with the 32mm carb.
So not a perfect match for my 36 carbs, but hopefully a lot closer than using the tz needle jets, especially as how hard they were to find !
    • GasketGuru
« Reply #14 on: April 04, 2019, 11:12:59 AM »
I'm currently running sugo internals too. R2 610 series needle jets, 6FI80-61 needles 2nd clip from top, 320/330 mains, sugo jet setter thing with no holes, 2.5 slides. 27.5 pilots. 55 powerjets (electronics not sorted yet so open all the time). Open carbs.
Full throttle drive is great. Very strong. Part throttle simply doesn't work lol. If you are below 9 grand it simply doesn't go if you are at anything below 3/4 throttle.
I'm going to revert back to nozzles with holes in, re-instate the VAJ blocks (zeel to control them), up the main jets and start again. It should drive from 5-6k with the fuelling right as it worked for me with the VAJ blocks before.
