Hi guys, thank you all for your oppinions and sugestions.
I really am trying to see if this is not serioully bad, kind a faillure gasket, or worst, a broken cylinder.
I did the caustic soda cleaning about 2 mounths ago, so i think it is allready dry.
Recentlly i cleaned tha carburators with ultrasound and they are much better.
I allready did 3 heat cycles in the garage, because i'm waiting for a new chain. Today in the last one, only one end can became a little brow liquid in the tip, justo a little bit, that i cleaned. Than bouth became very dry, what is strange is that after this 3 cycles no oil in the exhaust ends yet, so i oppened a little bit the oil pump, and put a bit of oil in the tank, witch is middle with gas. Tomorow will see if it is oiled or not...
Another strange thing, after cleaned the carburators, the bike starts fine first time, but after choke closed, seams to strogle to go up from 1500 rpm idling until 3000 rpm, in special when hot; after reach 3000 rpm, she goes very fast and good until 10/11, with no gaps or holes, like no problem. The spark plugs are new, so no collor yet.
BUT if i close one of the entries in the air filter box, than she runs fine in lower rpm´s, and goes from idling untel 7000/8000 with no gap, so i assume perhaps i have too much air entering in the engine in lower's rpm, or low gas, maybe a small pilot jet (it's all original inside the carburetors... Any ideas or oppinions are wellcome, please. I am about 500 meters upper the sea level, medium 20 degres celsius temperature, not much humithity, and gasoline is 98 octans. Thank you all for your help. Regards
