Author Topic: WTB 3XV SP cylinders  (Read 278 times)
Gtidave74
  • Newbie
« on: March 28, 2020, 02:57:40 PM »
Turning an R model into a track racer. Any parts for this are needed. I have acquired TZ fairings and am now on to sourcing engine bits. The crank and dry clutch will come much later. I am looking for a higher spec cylinder and power valve set up then what I have. As it’s being built I am not worried if it’s not the same power valve system that I have as long as they are complete. I am changing the CDI anyway. Thanks for any help.
Re: WTB 3XV SP cylinders
« Reply #1 on: March 28, 2020, 03:33:24 PM »
I'd advise that you have a read through all the different project threads if you haven't done already :-)
« Reply #2 on: March 28, 2020, 07:09:59 PM »
If it helps I can port the R cylinders to almost SP spec.. much cheaper than finding SP stuff.
« Reply #3 on: March 28, 2020, 07:57:09 PM »
Martin is "The Man" Gtidave74. Good pricing and service. Plus, you'll be dealing with a gentleman.
Gtidave74
  • Newbie
« Reply #4 on: May 25, 2020, 04:02:06 PM »
Thanks everyone I appreciate the input and advice I apologize for not responding earlier. I have found a 3XV 10 engine complete with dry clutch. I am wondering what is the best option for a head that has been cut I assume due to damage. Are there any out there? It’s a 3xv10 Y1 and what is the difference between a Y1 and a Y2? Thanks in advance
« Reply #5 on: May 26, 2020, 01:37:03 AM »
No physical difference between Y1 and Y2, more to do with the manual making references about left and right cylinders/head. (info courtesy of Juergen).
You will need to get someone machine and/or weld that head? The machining on that damaged head looks quite different from the other one, the squish band looks especially big..  Probably easier just get a spare from gecko?
