I can't help you on non-OEM bearings,but when I rebuilt a spare engine with new seals etc I had lying in my shed for 12 years,it did not occur to me to replace ANY engine bearings,crank was ok.
After 1,800 miles the bearing broke and collapsed dumping engine oil all over the rear including the tyre while I was out riding in Wales with my mate.
Luckily I was only travelling about 40mph and managed to stay on and stop with the rear end snaking about,the rear wheel was locked solid.Just before this happened I had been giving it the berries over NSL roads towards Bala.
Pulling the clutch in does nothing in your favour when this happens.
I WAS VERY LUCKY TO NOT END UP DEAD OR IN HOSPITAL.
When I eventually recovered the bike and stripped the engine,you could see the bearing had gouges and RUST on the inner bearing surface of the outer race causing the bearing to break up.
There is no way to see any rust on the inner side of the bearing.
Definitely replace with new on the grounds of safety on ANY engine stood for years in sheds/garages etc.
