This is fairly minor, but I've developed a problem finding neutral on my 3xv.The old clutch was that which came with the bike back in 2018. Those clutch plates were recently replaced with new ones from the YZ-125 and the springs with EBC, HD pieces. The clutch gives smooth engagement and the tranny shifts smoothly. Blipping downshifts is much more precise. But, it won't go into neutral while the engine is running. The free-play is on spec. The cable freshly lubed.
No, I did not disassemble the tranny.
If I kill the engine, finding the green light is easy.
Is this just a symptom of the clutch needing to be run-in longer?
I can probably play through this, but sitting on the grid holding the bike with the clutch can get be a bit of a problem.
Any suggestions welcomed.
