wipe the bottom of the engine off. run it again and just watch where its coming from. might take a warm up to get the oil thin enough to leak.
Oil drain bolt, right case cover gasket, centre of cases or even the seal that goes around the drive . hopefully not a crack or damage and just a leak
but at least you can take two positives from it , its not 2t oil and its leaking out not in.
