TZR 125 4FL
Started by cat_face, December 23, 2012, 02:02:02 PM
#15
Quote from: Warwick on December 26, 2012, 01:00:08 PM
Look again, Crank ;)... Or were they not 4FL plastics? 4DL maybe?
I may be under correction here :)
Took them back to the breaker the same day and exchanged for other parts.
Had the speed blocks and light metallic blue/turquoise triangle thing with the yamaha wording at the bottom.
Makes me think now........i was still po about the damage, might have been in too much of a hurry.
Think I will go back and see if they are still available.
nomoregt4
Hi Cat_face. I'm new on here too, just signed up 10 minutes ago.
The 125 4fl & 250 3xv fairings all have the same mounting locations. As someone else pointed out earlier the headlight hole is a different shape between the 125 & 3xv as is the rear seat fairing brake light surround. I definitely know this as I've had both sets of fairings & I've tried to mount the rear seat fairings from the 3xv onto my 4fl & it wouldn't fit around the rear light.
As for the fairings you're after. I have a set of fairings in the colour scheme of the 4fl if you're interested?
cat_face
Hi,
Thanks for responding my request :)
I'd be interested in buying both side panels (4FL type)
Do U have pictures?
nomoregt4
Yes I do. I'll upload them when I get 5 min ????
nomoregt4
Quote from: cat_face on December 28, 2012, 10:35:29 PM
Hi,
Do U have pictures?
You should have a PM by now Julien  8)
