avatar_Neal
3XV-50
Started by Neal, October 30, 2012, 09:39:42 PM
To me they look slightly touched on the inlet of the transfers - i will show you . The ones on the bike look untouched to me .
James' bike has TZ barrels on it .
So.....anybody with an SP port map to share??
This one has been around for ages, taken from a 91 SP I think.. don't worry too much about the outline of the ports, they had large chamfers which affects the shape on the paper, but the measurements are accurate. Generally the transfers are more than 38.5mm from the cylinder top, but these were a little higher, also the exhaust port is normally only 41mm wide.
zoomzoom
This one is also fairly common..91 3XVR-SP
Yeah that last one is not accurate sadly. It looks like the vertical distances have been measured off the port rubbing rather than off the cylinder. So the chamfers have been included.
