SW Motech Tang Bag fitting Ring
Started by Rasher, April 18, 2025, 11:54:51 AM
Rasher
Has anyone fitted an SW Motech Tank Bag where you have the rings on the tank filler the bag fits into?
I have several different size tank bags and the fittings on out other bikes, be handy to be able to use then on the TZR, but SW Motech do not list a fitting, I suspect it will be the same of some other Yahamha's of that vintage?
Anyone know???
Rasher
After sending some measurements they came back with a fitting for a "pro" tank ring, but I have the original bags so no good, will probably buy a cheapo magnetic jobbie for the odd times I need to carry something.
i use a small ogio bag on the tail. tiny bungee around the loops, front strap under seat strap, back one flids under. zero damage to bodywork and cant feel it. carries plenty.
