avatar_davewills4
Clutch springs torque setting
Started by davewills4, June 07, 2025, 11:25:52 AM
davewills4
Hi all, have replaced the shift shaft today   all went well until I had to torque down the clutch springs  bolts 8nto the pressure plate.Manual said 7nm,  5.1 ftlb so I set the torque wrench to 5 nm and  sheared off the bolt in the clutch housing, luckily I managed to tap out the broken bolt from out of the clutch boss. Have ordered some new bolts from yambits,  what torque do you recommend as 7nm seemed to be doing them up forever.  Any tips ? Cheers Dave
pnicho
Did you do them in stages diagonally? Manual says 2-3 steps of slowly tightening each one and eventually get to the right torque.
They will do up a lot whilst they compress the springs.
Current Bikes:
1968 Suzuki T200 Cafe Racer
1973 Hawasaki H1E
1989 Honda CBR250R (MC19)
1995 Yamaha TZR 250SPR
1998 Kawasaki ZZR1100
2002 Honda SP2 (Castrol Colours)
davewills4
Hi pnicho, yes I did only tighten them half a turn each time opposite bolt to opposite bolt I suppose they are possibly nearly 40 year old bolts so maybe weakened  after all the heat cycles and over the years     ?:-|
pnicho
Yeah possibly. :(
Hope you get it sorted.
Current Bikes:
1973 Hawasaki H1E
davewills4
Well I recieved my new clutch spring bolts from yambits, and rather than use a torque wrench to tighten them up just used a spanner and when they stopped doing up did  just a tiny bit more to cinch them up and they seem fine . Didn't want to risk sheering another bolt.
The new shift shaft seems to work fine as well :D
