3xv wheels +
Started by orcinius, November 13, 2014, 06:33:41 PM
4l04ever
Thanks for the pics.   I don't need the swing arm, as I have a frame and swing arm powder coated ready to go.  I could do with the rear wheel with sprocket carrier, rear disk, spacers, spindle and nut.   How much for all that?   I don't need the tyre, but you can leave it on if preferred.
Thanks
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
Zeeltronic Ignition System
3XV-1 Trackbike #2 project......
Paulyb44
Hi orcinius thanks for the pics
Would be interested in the front wheel
Preferably without tyre but doesn't really
Matter either way
How much for this ?
orcinius
#17
the tyres are only good for recycle, I can remove and dispose if you like so you can lower postage cost
as I told you I will split the price at half that's 110 for each wheel
front with discs, rear with disc and sprocket carrier
I won't strip the rear swing arm from spacers, spindle and nut. Since it's very unlikely that It will  sell afterwards
so it's 110 more for spindle nut and spacers and I give for free the swingarm
Thanks
for postage you make your arrangements with the courier
Paulyb44
If you can recycle tyre that would be good keep postage down
Price ok but I would prefer if you could organise
Postage at your end I have not Had much success with couriers
Locally never mind in a different country  ;D
orcinius
metafores.co.uk
Is based in England,
I'll only deliver the package  to the truck company that makes the trip from Greece to UK
Trust me I have done this quite a few times you will get better rates from there than me here
But if you insist just pm your full address and will call them
Thanks
4l04ever
#20
I will just have the wheel with the sprocket carrier and disk for £110.
I will have a look at the metafores website to arrange courier.  Which depot wouild you be taking the wheel to?  I presume they need weight and size details?
Thanks
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
orcinius
they have a depot at aspropirgos area
around 40 miles from where I am
pack will be around 55*55*25 cm
weight I guess around 15 kgs or less
can't be sure before I pack it
I want to  make one trip  so please if it's possible
wait for Pauly B44 to make his arrangements also
Thanks
you can also try this company http://www.asteras.co.uk/
they both use the same cargo depot just let me know your arranements
Paulyb44
No problem orcinius I'll go ahead with the front
Wheel also with discs
Will check website if you can give us final packed
Weight and dimensions of box would be a great
Help
orcinius
Hi update
removed the wheels from bike
and noticed a flat spot on the lips of the front wheel
will remove tyres on monday and have them checked
it doesn't look like crash damage more like from hitting a ditch while driving
will let you know when I have news
Thanks
4l04ever
Can you let me have the size and weight for the rear wheel parcel?
Thanks
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
Paulyb44
Ok thanks for letting me
Know
orcinius
Hi
both wheels are packed
size is 55*55*20 cm
and front weighs 7.5kgs
while the rear is 13
Thanks  ;)
4l04ever
Thanks.  Will get some postage prices sorted and get back to you.
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
Paulyb44
Great I'll get some prices from courier
And get back to u
4l04ever
I got prices from the 2 couriers listed.  £55 (maybe plus VAT) from metafores.  85 Euros (maybe plus VAT) from Asteras.   Not exactly cheap!   Any other options?
3XV-1 Trackbike
TSA Pipes
30.5mm Carbs
Modified Airboxes
