TZR 125R 4HW Fully restored
Started by TZRtim, May 09, 2016, 09:44:08 PM
TZRtim
 (-P) Thanks 4 the kind comments , it was colour taken from TonyB i think  3ma5 on this site . But its scheme is 3xv1 i think   ( the cyan should be Red ) and clearly the decals arnt std , a one off by the image works . So glad graham  could do it . Theres still a few tweaks id like done . The front fairing / headlight bracket needs paint or powder . May have the exhaust professional finished . But dyno it at 28.6 . This is good but for the Athena 170 is low - but then its porting is the same as the std 4fu barrel . Whan iv done 5000 miles ill re-place piston /rings and have bottom engine rebuilt - and ported to hopefully unleash maybe between 31-35 ? Who knows . All the best
ps ill take a few more closer pikkys showing abit more detail ...  (-P)
May the wind blow light and your groups shoot tight - UKV...  Biker and shooter for life ...
TZRtim
#46
Little ride out today and couple more piccys. Some chap pulled up beside me on a yam scooter Mmax or something? He said  I like the old bike it's very nice lol , he said with a big smile on his face ( open face helmet ) . I said thanks and tooted as we rode off! It's priceless riding this thing ::) 8)
Just thought id mention the lovely lady eddy who let me do this project in her garage , kind funny abit crazy but , unfortunately before the project was finished she had a fall , went to hospital , eventually came out and was being looked after in her home . But last Christmas eve she passed away . So sad . And actually some of the reason id got myself a project in the first place was at the time my 15 yo dog black Labrador  ( red ) was still with me but i knew he was ill and id have to loose him . He was my world . So in a sence this bike to me is very special .  I think red appeared in one of the photos during the build . I miss him every day .  So to try and keep occupied after that the tzr would help in a way . Anyway enough violin playing , all the best Tim...
nomoregt4
Beautiful bike Tim. Really good post to see progression from start to finish.
She's a keeper :)
Rich.
TZRtim
Hi folks , little update. Bikes had tmx30 fitted today and put on dyno for setup . Good news it has given the acceleration a boost right from 2-3 k so its gained 1ft/lb of torque, also its gone up on 28.6 hp to 29.7 but they were having detonation-compression issues around 8-9 k so recommend to have the head off to machine it some to help compression . Appart from that it would pull bloody well from 3k in 6th right up to about 100mph on the road test . almost there lol, then there sourcing a spare 170 barrel to have iron liner and porting done , that should up it more - time will tell . Atb
That's getting better...  :)
Easy way to cure a bit of pre-ignition is to retard the timing a bit. I'm happy to mod the head for you too if you wanted.
Not sure why you'd want to put a liner in the cylinder unless it was really scrap.. but oh well.. just let them do it eh.
TZRtim
Hi martin , the chap thats done the work has offered to machine head for free . I just got to whip it out (engine) for him to check first / compression test maybe? . Apparently he and pj both agree the iron is better when u have a nip up . But im no tech on this . Its his guidance im taking. He said if i can find spare 170cc barrel his friend would put in liner the he would port and we try that. If im reading right Athena on there website mention 37-40 hp are largely attainable with proper carb setup 30-34mm racing exhaust and , porting. Not sure if thats true and anyone has ever achieved near that . Hell id be more than happy with 33-35hp . What exhaust are you running? Id love to know your hp on the dyno as that 34mm carb must help things, was it a straight swap or have to modify inlet?
Well, the iron liner might be nice if you have a nip up, but it might increase the chances of it happening in the first place due to different heat expansion rates.. PJ know what they're doing though. Finding a spare cylinder is the hard part.. Who are you using for the engine work?
I run a 35mm carb, and yes quite a lot of work to fit, not just manifold, but cable adjustments too.. I run one of my own pipes on it, peaks at less than 10,000. Sadly the local dyno was sold a couple of years ago so I'll never know. I suspect mine's low 30's? not huge power, but it's been perfectly reliable.
TZRtim
Its a local chap rob pemberton @ spa motorcycle. Before that it was Dave parrys but he retired.  , he must have 20 plus years of engine builds tuning etc. They always have 3ma 3xv there , there  was 4x rd500s there a week or so back . He has a 2ma that of his own that is something like 58/59 hp featured in mcn i think last year . Yeah im looking for used barrel one did come up but he wanted almost new money for a used kit? Naa i thought he would be lucky to get that . So the hunt continues. Exhaust wise not sure if jl can make or do one, think there's not much available . Id probably have one of yours if you still made them :'( . If i had the space n set up id try it myself replicate some of it trying different expansion sizes etc hopefully finding the optimum. But thats a "pipe dream " really :))
Ah cool, I've spoken to Rob a few times, and made him some 350LC pipes recently for one of his customers. I still make pipes, just not 3XV ones, or indeed ones to fit the 4FL chassis. In theory I could maybe do a kit of parts if you  fancy welding them up, but I'd need a shape to follow.
Personally, I would just port your existing cylinder and put it back on..
TZRtim
Yeah i did think that, it would need a re-plate ? As heads got to come off to check its all ok . Why not , need a new gasket set too . More to think about
Shouldn't need a re-plate no.. unless some of the plating chips off, which is pretty rare. The only advantage of having an iron liner is being able to out to a larger size and run Blaster pistons with rebore sizes available (I think), rather than just being stuck with Athena pistons.
I've re-used the head gaskets a few times too, but if Rob's doing the work then he would err on the safe side of doing things and use a new gasket.
I guess the problem with getting other people to do all the work is it's out of your hands..
no smoke no poke
very nice job u have done congrats
no smoke no poke
Up and running after decoke
Ready for mot
no smoke no poke
Quote from: Martin77 on June 05, 2020, 10:38:05 AM
what on earth dellorto flat side carbs make 33 bph out of the factory no mobs on 124cc maybe get yourself a yhsa32 dellorto on it and decoke exhaust regular drops power and easy overlooked
no smoke no poke
Quote from: TZRtim on June 04, 2020, 10:51:58 PM
ment to quote on this comment sorry my bad
