avatar_rvt2002
Fuel Vacuum line(petcock)
Started by rvt2002, December 29, 2012, 04:40:31 AM
rvt2002
Would it run crap if i remove the vaccum line?
eyrey1
#1
NO IVE PLUGG'D MINE !  sorry and ive got an rgv fuel tap on
Quote from: rvt2002 on December 29, 2012, 04:40:31 AM
If you have a working vacuum petcock, you would need vacuum for it to actually pass fuel while set to the "on" and "reserve" positions.  It would pass fuel in the "prime" position, but would have to be turned off, or away from prime position, to stop the flow of fuel when the bike is not running.  If not turned off, you run the risk of overflow.
What's wrong with your fuel valve?  I think a replacement diaphram can be sourced reasonably, or you can just switch it to a on/off style valve as on a TZ or RGV (as I'm told)?
rvt2002
Im thinking of upgrading my petcock with na option of  "off"  instead of prime,on and res, most of the petcock i see dont have vacuum line. Im just sick of getting empty tank with a flooded crankcase. This always happened when winter comes. For some reason the lower carbs tend to crap out during winter time. I just want petcock that i can just put it off and not worry anything.
eyrey1
PUT AN RGV250 ONE ON THEY FIT PERFECT
rvt2002
Thanks :) what model of rgv250? VJ21 or 22? I was thinking of fzr600 since its more available here in US than rgv250 petcock.
Quote from: eyrey1 on December 30, 2012, 05:34:10 PM
eyrey1
it was vj22 but 21 is the same im pretty sure !
rvt2002
Thanks for the reply and links jjcsnoook.
rvt2002
I bought the FZR600 Petcock. No more over flowing carbs  ;D
Another fuel tap option! Great stuff!
Does the tap have a 10mm outlet or is it smaller?
rvt2002
Its a lil smaller compare to the stock one and the outlet comes out on the right side(stock is leftside)
Rzmax
Yes I have a vj22 petcock on mine as well and it fits perfect.
90' Yamaha TZR/RZ500 in the works
91' Suzuki RGV250
92' Yamaha TZR250SP
96' Aprilia RS250
