SUGO CDI for Borut... (ignition curves)
Started by 41juergen, March 25, 2013, 04:24:36 PM
Stroker I have a spare box to send, that won't require taking down a running bike (if that is what you have to do).  I can post it tomorrow, if you, or someone else has not already sent one to juergen.
I'll check here in the am for a reply.  If still needed I should be able to label and post in tomorrow.
stroker3xv
 jcsnook I posted mine today. It is a spare so no problems for me.
Yamaha RZ350 ypvs x2
Honda NSR MC28
Yamaha TZR 125
Yamaha LB 50
Yamaha TZR 250 3xv
Yuri
I can not wait to see all the maps
From what i can tell is that in 91 you where alowed to manufacture and use special F3 cylinders and heads
In 92 thy stoped the use of special F3 cylinders and you had to use the once that came with the motorcycle
That is why I think thy had a 70 and 80 CDI
The 91 and 92 sp heads are actually slightly different i've found. The squish is tighter on the 91 heads.
There were -70 and -80 pipes too so they changed those aswell
Yuri
It will be nice to see the 70 and 80 curve
So you've got a -80 box coming, do you still need a -70 then?
Yuri
Quote from: jcsnook on May 30, 2015, 02:55:42 PM
Yes a 70 is still needed
stroker3xv
Should be getting close to delivery date.  8)
Honda NSR MC28
Yamaha TZR 125
Yamaha LB 50
Yamaha TZR 250 3xv
Yuri
Quote from: stroker3xv on June 03, 2015, 11:43:55 AM
It will take 2 to 3 weeks to get there
injapan
I have decided to get a Zeel to replace my 9A,
Juergen have you already given Borut the data you have collected and if I understand correctly he will be supplying his Zeels with the different Sugo maps ? I guess this would make it really easy for me to start with the 9A map and adjust accordingly.
Good job collecting the data, thanks
TZR250R SP 3XVB Road X 2
TZR250R SP 3XVB Race
KTM250 TPI Six Days Supermoto
Yes, Borut already has the data, may be ask him to put them as a "standard" into the CDI for you (not sure if he will use our data or stick with his own ones).
Juergen
I wanted to ask - do the sugo cdi's operate the variable air jets ? If so are they controlled differently than with the stock cdi?
The air solenoids are mapped out on the stock CDI's but not on the sugos I see.
Yuri
Quote from: ybk on June 04, 2015, 01:13:41 PM
The air solenoids are blanked of on the sugo carbs
And the solenoids power jets are used instead
Wullie3XV9
Fantastic work, Juergen (& friends).  8) Many thanks for all your work with this, it's very interesting reading.
Looking forward to when you post the -70 & -80 curves.  ;)
There's always f@*kin' somethin' !!
Quote from: Wullie3XV9 on June 05, 2015, 11:10:09 AM
Yes me too Wullie, but I think they still need a -70 box.  I'd have to pull my tail section off to see what box I have on my bike.  It may be a -70...I don't recall now.
