SUGO CDI for Borut... (ignition curves)
Started by 41juergen, March 25, 2013, 04:24:36 PM
Can someone pm the address to send my Cdi to .
Thank you
stroker3xv
Hey Juegens. Just to let you know I have received my CDI.
Yamaha RZ350 ypvs x2
Honda NSR MC28
Yamaha TZR 125
Yamaha LB 50
Yamaha TZR 250 3xv
Yuri
Quote from: Neal on August 01, 2015, 08:29:25 AM
Thank you
I have send you the address
That's Yuri, I have only limited time to answer as being in holiday in US, will be back end of the week... ;D
And the pv graph:
Interestingly it starts at fully open..
Quote from: ybk on August 04, 2015, 04:27:35 PM
Yes, both the -70 and -80 do that. They sound quite raucous at tickover...  8)
Yuri
Thank you
Have you send the CDI ?
Yuri
Warick any up date on your cdi
Which one are you still missing?
Yuri
Completely slipped my mind in the Autumn because it wasn't convenient for Juergen the the last time it came up.
Flick me a PM, Jeurgen, if you still have the rig set-up and I'll send you the -70 for reading. Though it'll be pretty much the same as the -80 I expect.
I'm glad this has resurfaced
I would really like to see a TZ leaded and unleaded curve on here. A 92-94 and a 96-98
Yuri
Quote from: Paul on May 15, 2016, 10:21:52 AM
It will be interesting to compair the TZ to the TZR maps
So Yuri, sorry it took some time...  ;D
I got the data out of a 4DP-10 which was the TZ 4DP2 from '93 . It can be seen that they used a very high numbers of ignition timing because of using the AVGAS fuel. The blade PV open very rapidly compared to the rotary ones.
Attached the excel file..
Crikey, no wonder my mates 3xv nuked itself on the dyno with an extra 20 degrees advance on top of that!
Good work as always Juergen, thanks for sharing!
