Caliper rebuild kits
Started by JKV45, January 29, 2026, 10:47:34 PM
The sumitomo calipers are not that common so you will have trouble getting anything else. The powerhouse kit also has the center seals which I haven't seen anywhere else.
Otherwise the seals are still available from Yamaha.
not 3XV pro but seal must be used on other Yamahas (FZR250 / FZR400 / R1Z / TZR125 4FL)
found ref :
 - 3GM-W0047-00-00 => FZR1000
 - 3MA-W0047-10-00 => TZR250 but also XJR1300 2013 / F1ZSA 2021 / BT1100 ...
I've used PowerHouse (UK) in the past : TZR250 R 1993
I have the Powerhouse kits in my 91R, you can either buy their kit or send the calliper to Powerhouse who provide a refurb service should you prefer. I have done both without issue.
turbo_d202
I've just rebuilt my 93 RS calipers using the powerhouse/ brakemaster kit.
Perfect fit, no hassle.
I painted and put them them the ultrasonic cleaner myself.
This is a good video brakemaster put together - https://m.youtube.com/watch?v=1ZVSKDTaF3M&pp=0gcJCR4Bo7VqN5tD
busa1300
#5
I initially put on a set of these calipers before I got a set of TZ calipers.
From 1990's triumphs with same bolt pattern. Just ground down the triumph on them. Basically the same thing as TZ250 Nissin calipers (83mm spacing), and early GSXR calipers (90mm spacing) Lot more grip in them than originals.
Smoking for over 40 years.
TZR250SP...3XV2
RS250 Track day
You've made it look really nice and stock  8)
JKV45
Quote from: ybk on February 02, 2026, 09:46:04 AMYou've made it look really nice and stock  8)
Ya - he's good at that!
1991 TZR250R 3XV01, WI, USA
