avatar_m in sc
mirror blanking plates
Started by m in sc, January 10, 2025, 02:44:37 PM
m in sc
as an fyi, i made a few on the 3d printer at work. i finally got fed up w the stock mirrors, fit a bar-end on the LH bar (much better visibility)  and printed some blankoff plates. If anyone wants the stl file, i'll be happy to share it.
as a side note, the filament is just the abs red from BAMBU labs. Almost a dead match color wise by absolute chance. I have also since fit black stainless screws so it looks more 'factory'
The Japanese spec mirrors look much better than the goofy uk euro spec one's. Fzr250 and 400 from same time period are the same.
m in sc
they look great but work like shit. lol.
Nice  (-P)
Would they fit a 3XV also, not sure if the mounting holes are the same distance apart?
m in sc
Quote from: m in sc on January 11, 2025, 03:30:38 PMno idea. the stl file is here: https://2strokeworld.net/wp-content/uploads/tzr250/fairingcap_m5-1.zip
Many Thanks  (-P)
If you get a chance to measure the distance from the hole centres then I can do the same for comparison  (-P)
Cheers.
m in sc
here you go. 40mm. I did the holes for an M5, a washer and nut will need to be used on the inside of the fairing, just fyi.
Quote from: thump566 on January 11, 2025, 06:33:51 AMNice  (-P)
3XV mounting centres are a few mm wider apart. Can't remember how many mm off the top of my head, but sure the drawing could be modded easily enough with the 3XV centre to centre measurement added? Otherwise they'd be fine  (-P)
m in sc
is that your way of asking me to model it for a 3xv?  lol.
give me the dimensions.  8)
3XV is 47mm centres from my measurement just now. I have my mirrors removed and blanking bolts in.
m in sc
here you go. 47mm center to center, and obviously longer but otherwise identical.
https://2strokeworld.net/wp-content/uploads/tzr250/fairingcap1-3xv.zip
