SUGO CDI for Borut... (ignition curves)
Started by 41juergen, March 25, 2013, 04:24:36 PM
So Carl, interested? Would you loan me the SPR SUGO CDI for testing (I have also an SPR loom, so can plug in easy...)?
cheers
Juergen
Yuri
#76
You can ask him
http://pure2strokespirit.net/forums/index.php?action=profile;u=2
His cdi is at my house but I will only send it if he agrees to it
Koel. So many guys think plugging in a sugo box is the answer to derestricting.
eyrey1
Yuri
It is funny how Mark got this with a SUGO box
@Paul: you are absolute right, a SUGO box is IMO only for AVGAS with the whole kit. I will work out my own data with the Zeel, but for reverse engineering it is helpful for the simulations... ;)
Juergen
Yuri
Not all the sugo boxes where made for avgas
The 3xv-75 spr box is made for avgas
The 3xv-7k spr box is made for unleaded
That is the reason there is 2 sugo boxes for the spr
Juergen, I assume the reasoning is to have a usable map for either an ignitech or zeel? Have you been able to reliably extract a map from your existing CDI?
If so then Yuri can send both CDI's, would be interesting if we can get easily comparable maps.. (Same as Yuri though, if it breaks then you'll need to replace)
@Yuri: sorry my mistake: of course I ment only the SP versions.... ::)
@Carl: yes I have checked my -10 and -40 CDI and will post as soon I have the data put together in a excel file... :D
And of course I will replace if I damage it  ;D
Yuri
If you want I also have a 3xv00 restricted box I can send you
What country are you in Juergen?
I would really like to put the 4DP cdi on your machine
What data are you able to extract?
I would be prepared to do dyno runs and supply final Zeel data for use on a standard TZ to match oem cdi.
I use the http://www.ignitech.cz/zdroj/exe/dccdip2_race.exe program to plot curve data to give a visual
It cuts me borut has not added this simple and useful tool to his software
Yuri
#86
Paul are there unleaded cdi boxes for the 4dp ?
I forgot I can also send you a clock derestricting box to test what it is doing
Quote from: Yuri on April 12, 2015, 01:48:39 PM
Yes it's called a 4TW box  ;)
I have a 75 cdi but can only commit to send it after the season  :-[
4DP-10 is leaded Avgas but after that I am not sure. 4TW is definitely unleaded
What box is this ?
I would be interested to compare settings I have put in versus what the data capture tells us. That would cut out most my concerns.
Yuri
It is just I think a m-max box
