What causes four stroking
Started by Robbi347, April 13, 2024, 07:41:02 PM
Robbi347
Just had engine out and fitted new crank seals as it was burning gear oil. Everything back together but when starting it's 50/50 whether the bike will start ok or four stroke. My question is what causes four stroking?
Robbi347
Can that go out? Flywheel is keyed and pick up is not adjustable?
tzar250
Maybe mixture too rich?  Did you change the oil pump seal as well?  I think that can also leak (especially if after-market) and let gear oil mix with the 2 stroke oil, if you had been noticing a drop in gear oil level.
Robbi347
Yeah could be too rich. Would moving needle position be enough or is it a jet change do you think ?
Mad Jack
Check that your chokes are turning off properly as I've had this happen on one of my 2 strokers years ago
Robbi347
Quote from: Mad Jack on April 15, 2024, 10:51:45 PM
Cheers , I'll check that
Jim Lyon
Was it running clean before the gear oil problem? If so, it's doubtful that the carb. settings are the problem ! Has gear oil in the wrong place fouled your plugs up? - I don't know how long you've had the bike, but when it comes to carb. related problems, the float bowl height is ignored too often.  While apart, it might be worth considering running the carbs through a vapour bath? Certainly easier to check than another engine rebuild !
YAMAHA RIDERS GO IN DEEPER AND COME OUT HARDER
